Just got new i7 8700k to replace my i5 8600k. I am using a Cryorig C1 cooler. I have read about other builds using similar or worse coolers and I figured this would be fine. After about an hour of putting my machine together, I load up windows and HWMonitor to see that my temps are easily 85-95-100c just from basic windows loading. Obviously this is not acceptable and even using my overclocked i5 8600k I did not see such horrible temperatures.
What is going wrong here? The TDP of the chips is the same.. Did I miss something?
___________
Update. In my rush to get this build completed and in my exhausted state, I didn't want to apply too much pressure to the board via the CPU mounting. I have since screwed the cooler down tighter and my max CPU temp is below 80c after running ASUS Realbench (a GPU and CPU stress tester). I am undervolted to 1.1v on an all core 4.3ghz overclock). Things are looking good!
https://linustechtips.com/topic/905620-help-i7-8700k-temps/
did you remove the protective covering from the cooler base plate before mounting it?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/905620-help-i7-8700k-temps/#findComment-11136176
then it sounds like either A) bad mounting, or B) Bad software reading. I would put my money on bad mounting of the cooler.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/905620-help-i7-8700k-temps/#findComment-11136179
Could be the thermal paste application/mount, if there is an air bubble or not enough paste the transfer would be bad enough to spike temps simply from booting
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
https://linustechtips.com/topic/905620-help-i7-8700k-temps/#findComment-11136180
It seems to be mounted properly. If I press down on the cooler with my hands and watch the temps, it seems the same.
https://linustechtips.com/topic/905620-help-i7-8700k-temps/#findComment-11136183
There is a tad bit more than a pea sized amount on the IHS
https://linustechtips.com/topic/905620-help-i7-8700k-temps/#findComment-11136185
is the BIOS up to date on the board?
Community Standards
"Beast Mode"
https://linustechtips.com/topic/905620-help-i7-8700k-temps/#findComment-11136196
Just now, CrippledROBOT said:
Yes
based on the information provided my conclusion is that A) the protection for the base plate is still on or B) bad mounting. Take it off and re-mount it.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/905620-help-i7-8700k-temps/#findComment-11136203
I had used this cooler for 5 months on my i5 8600k with no problems. I have long since removed it.
https://linustechtips.com/topic/905620-help-i7-8700k-temps/#findComment-11136207
alright, then remove it and remount it.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/905620-help-i7-8700k-temps/#findComment-11136211
UPDATE. This is going to sound extremely stupid, but I removed my fan from the CPU cooler and re-tightened it. I am now getting better temperatures than I did on my i5 8600k. I am not sure why this is, but perhaps the cooler was never quite mounted properly
https://linustechtips.com/topic/905620-help-i7-8700k-temps/#findComment-11136218
Yeah things often are looser than people realize, at least it works now :)
https://linustechtips.com/topic/905620-help-i7-8700k-temps/#findComment-11136236
I think I must have screwed something up (no pun intended) when I initially mounted this cooler. Now that it is much tighter, I have shaved off about 8c from my i5 8600k at the very same stress test... Thank YOU and thank you @legacy99. Been a long day at work and freaked out when I saw that my incredibly tightly packed PC wasn't working!
So far it is working very well!
https://linustechtips.com/topic/905620-help-i7-8700k-temps/#findComment-11136246
No problems :) Wasn't trying to sound confrontational or anything. Sorry if I came across that way, but glad you were able to fix it with the remount!
Community Standards
"Beast Mode"
https://linustechtips.com/topic/905620-help-i7-8700k-temps/#findComment-11136250
