Monitor Plz
Solved by Nas,
The question isn't what monitor can handle your PC, a CRT from 2003 can 'handle' your parts fine, the real question is what kind of resolution can you PC handle. You should probably go with a 1080p monitor considering you have a 1060. Go for a 120Hz+ if you're into competitive FPS games but other than that a normal 1080p 60Hz of any size 21.5" or above should be fine.
Featured Topics
xJDL ·
Posted in Troubleshooting0 -
Marie Rose ·
Posted in Power Supplies8 -
7
4
7
14
10
Tamgam12 ·
Posted in New Builds and Planning6 -
remo233 ·
Posted in New Builds and Planning25 -
5
