Coole Master Hyper 212x Issue
OpticFusion
Hi
I am having issues installing the Cooler Master Hyper 212x, which I am been trying for a few hours.The issue is the X bracket is not level on one side to the other. Here are the some pictures to show the problem.
Thanks
The Asus UX305 has an Almighty Intel core M-5Y10 0.8GHZ, GPU Intel HD 5300 Windforce, SDD 120GB, Passively Cooled, 1920x1080 Matte Screen, An Fantastic ICEpower Audio Making my House Shake and Having more ports then a MacBook btw this not an advertisement.
holy crap this throws me back to when i had the exact same issue, i'm trying to remember how i figured it out
Oh so other people have had this issue before.
yeh i remember the instructions being complete crap and spending a full day before i figured it out
Here is the X bracket installed without the CPU cooler.
I'g going to dismantle my media pc to figure out what i did, will get back to you within 5 minutes
check to see if those are the right standoffs or if they're installed properly, and check with the manual.
I tried to put a lot of force but still it doesn't want to go in, which also made me feel a bit uncomfortable.
Ok thanks
I check the manual  and I found out that I made one mistake and I corrected it but the same issue still occurs.
My board is the LGA1151 and going to be running a core i5 6600k
4 minutes ago, OpticFusion said:
Ok thanks
Ok, i figured it out, somewhere in the box or wherever your building your pc is a small bag containing  4 hollow plastic circles, they sit between the standoff and the motherboard and give it the extra high required, photo included:
mine was a haswell i7 but same mounting system
Oh but I can't seem to find those fittings, let me check again.
Would it be in a separate box you mean?
i found mine under the table i was building the pc on, they don't come in the box with everything else
that was poorly worded, they come with the cooler, just not in the container with all the other mounting hardware
What about these, which I found in the box,
no those are to let you mount your own fan to the cooler, the part your looking for are 4 black circles, about 1.5cm across and 2cm deep
You mean this container?
Oh okay
let me watch a unboxing video.
is this the screw you mean?
Can you please explain to me where to find those 4 circles?
Thanks
I had it but not to this extent mine was enough that i could just push it down but try to screw in the opposite corners first im pretty new to pc building though so i wouldnt listen to me to much ?
