Dear all,
After the better part of the decade passed, I decided to splash the cash and got myself an i5 8400 (mobo and all). My old CPU (AMD FX-4170) had some cooling issues, so I had purchased a Zalman CNPS5X Performa, which worked wonders. I have this cooler for quite some time. Now, since the i5 comes with a stock cooler, I was wondering if I should use my Zalman instead (it's gonna be a major pain to discover where I've put the parts for fitting it on a 1151 socket - a proper excavation I tell you!). So, thoughts? Stock or aftermarket? I'm leaning towards not bothering, since the new chip has a 65W TDP, while my old (crappy in terms of thermals) CPU had a TDP of 125W (lower consumption, lower temps, amarite?).
https://linustechtips.com/topic/904961-i5-8400-cooler/
Stock cool is adequate for a non overclockable CPU. You will be just fine using the stock Intel cooler on there.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/904961-i5-8400-cooler/#findComment-11130292
if you have the Zalman one already and can easily find it's bracket (either in storage or online for cheap £5 max proabably) then use it, if you can't get/find one then use the stock cooler as that is good enough, I would replace the thermal paste though, with better stuff (that's just me though stock paste probably is good enough)
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
https://linustechtips.com/topic/904961-i5-8400-cooler/#findComment-11130299
22 hours ago, LoGiCalDrm said:
If you can get brackets, use aftermarket cooler. Stock is fine for temps, but aftermarket ones are usually bit quieter for same performance numbers.
I came back to say that and just saw your comment! Been using the new cpu a couple days now and it's great, thermals are great too. But the stock intel cooler is way louder than what I was used to with the zalman! I'm going bracket-hunting this weekend or get a new one, like BeQuiet!'s Pure Rock Slim.
For the record, thermal juice was changed asap.
https://linustechtips.com/topic/904961-i5-8400-cooler/#findComment-11134541
