Hello I'd like to know if I can connect 2 local networks and make them work as a single network if it's possible, a friend will be staying at my place for a while and he's bringing his rig so here's the thing
There are 2 routers;
Router #1: Friend's rig + My sister's computer + Router #2
Router #2: My rig + NAS + Laptop
we'd like to access the NAS from the computers that are on router 1 but I'm not sure how to make it work, everything is configured as gigabit full duplex, and my friend and I will be playing games over LAN too
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/904749-connecting-2-lan/
5 minutes ago, Electronics Wizardy said:
Why do you have 2 routers?
Network map?
Normally just use a switch, or turn of nat on the second one.
the main router has only 4 ports plus there's no room for the NAS where it's located
7 minutes ago, Lurick said:
Disable NAT and DHCP on the second router so everything is on the same network.
I'll try
https://linustechtips.com/topic/904749-connecting-2-lan/#findComment-11128254
2 hours ago, Electronics Wizardy said:
Then get a switch, not anouther router.
I ordered a $50 PSU yesterday that was why I was trying to avoid buying new stuff until next month or so
for the moment disabling nat and dhcp worked but only at 100mbps, 1gbps refuses to work, currently trying to figure out what's wrong
https://linustechtips.com/topic/904749-connecting-2-lan/#findComment-11128721
Y’all can’t come up with $30 for a switch between the three of y’all?  Connect router -> switch -> everything else.
https://linustechtips.com/topic/904749-connecting-2-lan/#findComment-11128913
