so my chrome has started to open on startup and its causing my computer to slow down dramatically as it is using most of my disk and a high level of cpu in task manager .
does anyone know how to solve these issues?
attatched is a screenshot of my task manager.
the chrome open in thee screenshot had 2 tabs open when it stared up.
https://linustechtips.com/topic/904650-chrome-using-too-much-resources/
Do you have any Chrome extensions you have recently installed? There has also been malware used to mine cryptocurrency going around that uses a decent amount of resources so that may be a possibility too, especially since many are browser-based. Worth doing a scan with Malwarebytes and a reputable anti virus such as Comodo if you haven't already.
i havent installed anything or tried to mine anything either
You wouldn't have had to mine before - the malware doing it without your permission could have come from any number of sources.
I'm not saying it is definitely malware, but I would treat it with suspicion as Chrome certainly isn't a browser you'd expect to strain your PC without any extensions installed.
I'd run some anti virus scans like I suggested - at least that would give you peace of mind there isn't dodgy software running anyway.
