Hi guys.Today i downloaded and installed GTA:San Andreas and when i tried to run it, it said ''You need atleast DirectX 9 Version".As far as i know i have 11.Then a tab from Windows Update has showed and it said to install (i think it was DirectX Update or something like this).I Installed it and then i ran the game, but the fps was arround 15-20 even on the lowest resolution... How to recover my DirectX version because when i tried to run Fortnite my fps was dropping really hard... My pc specs are GTX 1050Ti and G4560.
https://linustechtips.com/topic/904635-problems-with-directx-gtasan-andreas/
All I know is that DX versions aren't compatible with each other. You need DX9c for older games and DX11 for newer ones. Just reinstall both and update your GPU drivers too.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Try this. http://www.tomshardware.com/faq/id-3496050/fix-gta-san-andreas-requires-directx-error.html
FPS dropping in Fortnite probably not DX related.
