Introducing SpeedUP, a batch-file Open-Source Project.
NOTICE: This Project only Has files for Windows 10 at the moment., Any other version will crash the program due to no scripting.
WARNING: This currently is in Alpha, EXPECT Bugs...
Do you have problems with a slow Computer (Trying to sound like Billy Mays!). Well Team SpeedUP is here to help you. We provide fixes for slow PCs in the form of batch files. We host everything on GitHub so you always have a source to get it from.
If you don't believe us just Right-click and click edit, then you can view all the code included.
NOTICE: you will see multiple Command Prompt windows open, they are detecting the Windows version (Still only working with Windows 10 at the moment)
https://github.com/TeamSpeedUP/SpeedUP-alpha/releases
Thanks for viewing this! :D
https://linustechtips.com/topic/904603-alpha-speedup/
Thanks boss, my Windows 10 computer is amazingly much faster after I ran your software and upgraded my HDD to an SSD!
Not sure which of the things did it though. The upgrade to the SSD or running your program which literally only detects which version of Windows 10 you have and injects you with a nearly lethal dose of placebo and a whole lot of nothing.
https://linustechtips.com/topic/904603-alpha-speedup/#findComment-11127187
