my i5 8600k is touching 80 in prime 95 tests.. i have coolermaster hyper 212x in push pull, and a zotac gtx 1080 amp extreme which touches 75, whats the issue?.. two cooler master sickle flow fans are taking in air and one sickle flow with one nzxt case fan is exhausting.. ambient temps are 33.. whats ther issue ? applied thermal paste in fine way.. so what could be the issue?
https://linustechtips.com/topic/904284-i5-8600k-temps-help/
Is this at stock speeds/voltages? If so, its well known that when you run a stress test at stock, it will pump in way to much voltage for what is actually needed to complete the test. Best way to correct this would be to manually set your voltages in the BIOS to like 1.2v or somewhere in that ball park and test. This will likely reduce temps a good amount when stress testing.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/904284-i5-8600k-temps-help/#findComment-11124411
i am noob at temps.. dont wanna touxh.. i am considering changing the exhaust fants to something better.. will that help?
https://linustechtips.com/topic/904284-i5-8600k-temps-help/#findComment-11124416
Normal temps. Those chips have issue where mobo draws more voltages than what is actually needed. You could get tad lower temps with fixed volts. But not much under 75C as 212 Evo is still budget cooler.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/904284-i5-8600k-temps-help/#findComment-11125006
Those temps are fine. What motherboard are you using? Are you using the default motherboard settings?
https://linustechtips.com/topic/904284-i5-8600k-temps-help/#findComment-11126704
