Hello Everyone!
I am looking to build my very first pc and could use some advice as to what I should do. I've done a ton of research but I still feel like a lot of it is going over my head, so I am trying to get some different opinions.
1. Starting off, I plan on useing this pc for gaming as well as to expand my youtube channel with digital art/animation. My budget is around $1500 US dollars though I can afford slightly more if absolutely necessary.
2. I do not have any peripherals yet, though I have a separate budget for them. For this thread I am mostly concerned with the computer itself. I have a friend with a spare 500w power supply who would be willing to give it to me if I end up needing it, but other then that,this build is completely from the desk up ?
3. Also, I do not need this computer right away. If I can wait this long just to afford one, then I'm sure I can bring myself to wait a little bit longer to ensure better quality. Though I'll admit I'm really excited to get it up and running!
4. I'm gonna list the parts I have in mind so far but it's all open to change. Also important to note, I did run them through part picker but I know sometimes its not 100% accurate.
Okay so here goes!
- Intel - Core i7-7700K 4.2GHz Quad-Core Processor
-Noctua - NH-D15 82.5 CFM CPU Cooler
-MSI - Z270 GAMING PRO CARBON ATX LGA1151 Motherboard
-G.Skill - Ripjaws V Series 16GB (1 x 16GB) DDR4-3200 Memory
-Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive
-Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
-MSI - GeForce GTX 1060 6GB 6GB GT OCV1 Video Card
-Phanteks - Enthoo Pro ATX Full
-EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply
-Microsoft - Windows 10 Home OEM 64-bit
There's everything I've found so far. Please let me know what you think and thank you for your time! ?
https://linustechtips.com/topic/903653-my-very-first-build/
Yeah, don't get the 7700K. The 8600K beats it, even in gaming.
There's so many things I would like the change here. Could you give me the link???
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/903653-my-very-first-build/#findComment-11117542
You're going to need a CD drive for the Windows 10, Get another stick of Ram for better Stability, You Can get a Ryzen 7 with 2 extra cores and a Liquid Cooler for it and still come in on your budget. Unless you plan to game in 2K or higher there's no reason to have a 1060 you can get away with a 900 series or even a AMD card. Also you don't need a i7 for gaming a i5 will do just fine all your doing is paying for a higher base clock
https://linustechtips.com/topic/903653-my-very-first-build/#findComment-11118200
2 hours ago, The Elf-ish Lass said:
Right now it is just at the $1500 dollar mark
which country are you in?
https://linustechtips.com/topic/903653-my-very-first-build/#findComment-11118538
Yeah I was wrong looking at benchmarks Intel beats AMD unless your going with the Skylake series. As for the 15-8600K beating the i7-7700K that information is false looking at benchmarks the 7700K performs slightly better in cpu related tasks. As for your card I believe a RX 500 series would suit your needs unless you plan to game in 2 or 4K then go with a GTX card. I'd recommend staying with Intel if you want to do intel but upgrade to a Coffee Lake, if you want to save money you can get the Ryzen 7 1800x its only $5 more then the i7-8700K  and has two extra cores. I'll make a parts list and link it
https://linustechtips.com/topic/903653-my-very-first-build/#findComment-11118539
the RX 500 series ranges from the 550 to the 580, entry-level to mid-range GPUs. same thing with just saying "GTX series", except now it means everything from a GTX 260 to a 1080ti. the i5 8600k is better than the 7700k since it has 2 more cores compared to just 4 with HT.
he can just download the ISO files from microsoft, burn them on a usb drive and install it from there. and the i7 has HT which the i5 doesn't to help it outperform. if you don't know what you're talking about then don't come and mislead others.
https://linustechtips.com/topic/903653-my-very-first-build/#findComment-11118573
So I'm not sure if your case included a Tempered Glass side panel but I sourced one for you just in case. Having extra wattage in your power supply is better then having just enough so you can upgrade in the future so stick with a 650 watt. As for the board most Intel boards only come with two USB 2.0 headers same with AMD so if you'll need access to more then two headers you'll have to buy a hub  https://pcpartpicker.com/list/YLZnQZ
https://linustechtips.com/topic/903653-my-very-first-build/#findComment-11118597
CPU: Intel - Core i7-8700 3.2GHz 6-Core Processor  ($299.89 @ OutletPC)
Motherboard: Gigabyte - Z370P D3 ATX LGA1151 Motherboard  ($95.89 @ OutletPC)
Memory: Team - T-Force Delta RGB 16GB (2 x 8GB) DDR4-3000 Memory  ($174.99 @ Newegg)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($78.99 @ SuperBiiz)
Storage: Toshiba - 1TB 3.5" 7200RPM Internal Hard Drive  ($42.89 @ OutletPC)
Case: Thermaltake - Core G21 Tempered Glass Edition ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($44.99 @ SuperBiiz)
Other: GTX 1070 ti + B350M mortar ($692.76)
Total: $1470.39
Generated by PCPartPicker 2018-03-08 11:23 EST-0500
you can get os from reddit for $25.
https://linustechtips.com/topic/903653-my-very-first-build/#findComment-11118647
CPU: AMD - Ryzen 7 1700 3GHz 8-Core Processor  ($279.89 @ OutletPC)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($29.99 @ Newegg Marketplace)
Motherboard: MSI - X370 SLI PLUS ATX AM4 Motherboard  ($121.49 @ SuperBiiz)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($179.99 @ Newegg)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($57.89 @ OutletPC)
Video Card: *XFX - Radeon RX 580 4GB GTS XXX Edition Video Card  ($346.76 @ Amazon)
Case: Silverstone - Redline RL06BR-PRO ATX Mid Tower Case  ($74.99 @ Newegg)
Power Supply: SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($83.99 @ SuperBiiz)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($92.99 @ Adorama)
Total: $1346.97
Generated by PCPartPicker 2018-03-08 12:45 EST-0500
I wasn't sure what kind of animation software you were using so I just went with a 1700, you may be able to drop it down to a 1600 to save some money though. The filter picked out a 4GB 580 as the GPU which I decided to just leave. The 8GB is considerably more expensive but the 6GB 1060s are not that much more expensive if you want one of them instead. I just used a parametric filter since the market is all over the place right now.
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
https://linustechtips.com/topic/903653-my-very-first-build/#findComment-11118999
Total: $1346.97
Thanks for the list. I'll probably be using Adobe Flash to animate, (it's only 2d animation) if that helps at all.☺
https://linustechtips.com/topic/903653-my-very-first-build/#findComment-11119056
In that case I would try something like this:
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($188.90 @ OutletPC)
Total: $1255.98
Generated by PCPartPicker 2018-03-08 13:24 EST-0500
It is listing a Pentium 4 as the minimum processor so I don't think you need all 8 cores, might as well save a bit of money.
https://linustechtips.com/topic/903653-my-very-first-build/#findComment-11119160
USB will work.
8700K gaming performance is much better than 8600K.
AMD cards can be as fast as competing NVIDIA options.
Ryzen 7 is slower for gaming, and just as fast for multithread applications.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/903653-my-very-first-build/#findComment-11119770
