Hi.
I was wondering if PSU can fit in any case.
I mean some case specification shows what size of PSU will fit.
Whatever if it’s  ATX12V or ATX PS2. But some don’t show anything.
So, my question is: “ The cases that don’t show what PSU should put in can be put with any size of PSU no matter what??.”.
thinks and I hope explain.
https://linustechtips.com/topic/903459-psu-size-and-right-case/
Depends, most of the time they say what PSUs they support further down in the spec sheet. If you are unsure about it just write their support. I wouldn't go with they way that that case firs all, if you get one that doesn't fit it didn't go well.
    Quote=Reply      Feel free to tag me or sth if you have questions about Liquid Metal :) ROCKETS ARE LIFE        My current build:
CPU: I7 6700k@4.7Ghz 1.31sth V; Liquid Metal (Thermal Grizzly Conductonaut) | Cooler: Corsair H100iv2 | GPU: HIS R9 390 | Motherboard: Asus Z170-A | RAM: 16GB 2133Mhz HyperX FuryX | Storage: 1x 250GB Samsung 960 Evo 1x random 4TB 7200RPM HDD | Case: Lian Li Alpha  550W | PSU: Corsair RM650i | Misc.: 6x Lian Li 120mm Bora RGB Fans
My Build Log:
https://linustechtips.com/topic/903459-psu-size-and-right-case/#findComment-11115638
8 minutes ago, thelordofwarr said:
Depends, mosten they say what PSUs they support further down in the spec sheet. If you are unsure about it just write their support. I wouldn't go with they way that that case firs all, if you get one that doesn't fit it didn't go well.
So, the case that didn’t show what PSU I should put in can actually put anything in it right???.
https://linustechtips.com/topic/903459-psu-size-and-right-case/#findComment-11115644
2 minutes ago, Azam-45 said:
Molten?
It's evening, excuse my mistakes or don't bother about them, I think you still understood what I wanted to say.
My Build Log:
https://linustechtips.com/topic/903459-psu-size-and-right-case/#findComment-11115653
most mid and full towers will be able to house most ATX psu's its when you bump up to the extreme 1200w and higher units that the length of the power supply actually comes into play but ATX is the standard (unless your working with small form factor) and almost all cases have proper mounting for it. If you have a specific case that you are looking at though and know what psu you would like to use that would be helpful though.
Folding Community Board:
Also check out our Official Folding Month event:
https://linustechtips.com/topic/903459-psu-size-and-right-case/#findComment-11115825
2 hours ago, Azam-45 said:
Hi.
Depends on the Case.
Some Cases only allow 140mm deep PSU, others something up to 160mm and others don't really allow ATX PSU at all..
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/903459-psu-size-and-right-case/#findComment-11116103
