Installing fans problem
HairyPotter
So i got 2 extra fans for my s340 elite case with the b150 gaming 3 mobo and it only has 3 fan ports where do i connect my forth fan? Can i connect it to the cpu fan port?
if you have an empty cpu fan or cpu fan optional port in your motherboard you can plug it into either of those and it will work fine. It will be controlled by the cpu temps and might run a bit louder/higher rpm than the other case fans depending on your fan profiles but nothing massive.
Winning an argument with a woman step by step
step one - talk to her
step two - fight with her for 2 hours even if you are really right
step three - admit that she is right for the sake of your safety
step four - realize that you have accomplished nothing and she still thinks you were wrong and now she thinks you are even more stupid
GTX1080ti, I5-4690k, ASUS Z97 PRO-GAMER, 8GB DDR3 1600mhz, Hyper 212 EVO, Tt view 31 RGB.
Splitters are one cheap way to add more fans. Each header can power 2-4 fans.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
