RAMPAGE V EXTREME + 2x 980 Ti's (Reference)
MrPsych0
Go to solution Solved by airdeano,
due to the lane assignments, you'll have to run 2-way first card in top red x16 slot and second card in the last x16 (below the black x16).
40-lane - x16/x16
28-lane - x16/x8
if GPU is installed in 2nd x16 slot, the GPU will not be recognized for SLI.
Hi everyone!
I'm a bit confused with these SLI Option's that the Rampage V Extreme haves and what SLI Bridge should I get for it because I want an "older" SLI combo with two ASUS 980 Ti's (Reference ones)
I know it's out dated and stuff, but i'd wish to stack'em like this image here:
My question is, is this possible? Or I have to use space like the next image?
If anyone rocking this setup could make a photo about it or smth, It would be cool.
Cheers,
DarkK1d
• CASE: » CoolerMaster C700M » •  MB:     » ASUS ROG RAMPAGE VI EXTREME »»» LGA 2066 •  CPU:    » Intel i9-9980XE Extreme Edition - 18-Core @ 3.00Ghz •  GPU:   » Inno3D GeForce RTX 3090 - 24GB  GDDR6X •  RAM» Corsair Dominator Platinum - 64GB DDR4 3200Mhz
• CASE: » DeepCool Matrexx 4F » •  MB:     » MSi GodLike Gaming X99 »»» LGA 2011-v3 •  CPU:    » Intel i7-6950x Extreme Edition - 10-Core @ 3.00Ghz •  GPU:   » MSi GeForce GTX 1070 Ti GAMING  - 8GB  GDDR5 •  RAM» Corsair Vengeance RGB Pro - 32GB DDR4 3200Mhz
You just need a longer SLI bridge. The one shown in Nvidia's picture is a 2-slot long bridge while the picture from someone else in a 4-slot long bridge.
Desktop benching:
Are you sure about that? I'm talking about a specific motherboard being:
https://www.newegg.com/global/hu/Product/Product.aspx?Item=N82E16813132505
  • 3 weeks later...
anyone?
Well if you want to run them like in the first pic, which wouldn’t be smart given better options you would need the bridge you first posted.
Each vendor has a different naming scheme for spacing so find a design you like then go from there.
Second pic spacing would  be better
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
40-lane - x16/x16
28-lane - x16/x8
Asus rampage v extreme SLI
x1 & x3 pcie slot for max bandwidth if you have enough cpu lanes.
Now
20170828_223410.thumb.jpg.f9959f7b7a8a90dbfd9859cdecd2cd37.jpg Then
  • 2 weeks later...
Thanks everyone for the kind replies! :)
