Well my problem started when i wanted to iincrease my "Vram" on my laptop that i got for christmas it currently has 512 mb of vram And its a amd 7410 apu from hp and its the notebook series and when i got into the bios i cannot find the option to increase my "vram" so is it just i cant increase it at all or is it a different menu? i will leave a link to the place on my laptop
https://www.walmart.com/ip/HP-Black-Licorice-15-6-15-F387WM-Laptop-PC-with-AMD-A8-7410-Processor-4GB-Memory-touch-screen-500GB-Hard-Drive-and-Windows-10-Home/47836539?action=product_interest&action_type=title&beacon_version=1.0.2&bucket_id=irsbucketdefault&client_guid=d32bf5fe-b3cf-4216-3be3-99e3186c6e2d&config_id=2&customer_id_enc&findingMethod=p13n&guid=d32bf5fe-b3cf-4216-3be3-99e3186c6e2d&item_id=47836539&parent_anchor_item_id=51975839&parent_item_id=51975839&placement_id=irs-2-m2&reporter=recommendations&source=new_site&strategy=PWVAV&visitor_id=aX3i1zRKaP9_9rFa_j5Bz4
https://linustechtips.com/topic/902920-help-with-incresing-vram/
I am not too sure but I believe its all relative to the how much ram system has, 4gb ram results in 512 allocated vram BUT that being said there might be hidden bios menus (google that up)
i am going to put a extra 4 gigs of ram in the laptop in a few months so
you should have created this thread in "few months" then.
You dont WANT it pushing to system memory, you will get MUCH less FPS that way, you need a laptop with a better graphics card. Also, not being mean, but you may want to learn your stuff a little more if you plan to buy a PC for anything more than day to day use.
It's and apu. Apus generally don't have dedicated memory and Instead use the system memory.
i didnt buy it i got it for christmas dude my  dad got it for me becuse i dont have a job at the moment plus its decent for the cost i can run gta 5 between 20-30 fps right now it not suppose to be a forever pc its only going to be used for 1-2 years wile i finish high school,get a summer job,save up and get my new pc bought or win a pc if possible(with my luck) not
