at microcenter they have bundle ryzen 7 very good deal. special 1800X bundle with motherboard.
1) Can I build ryzen 7 1800x without GPU for now. is ryzen 7 build in intergrated graphic . I'm  want to buy GPU when is lower price. right now is expensive.
2)  I'm not doing overclock . Can this liquid cooling Corsair Hydro Series H80i v2 Extreme Performance Liquid Cooling System will work good ryzen 7 1800X, 1700X, 1700. I want to build simple  PC. I want less fans as possible. I don't like the noise. I consider use this liquid cooling mount it in back replace exhausted fans. I want less fans. I want whole case have 1 fans or 2 fans. that's it. Could I able to do that. If you know any case and air cooler CPU work good ryzen 7 . please recommend. Thank you.
http://www.microcenter.com/site/products/amd_bundles.aspx
http://www.microcenter.com/product/458866/Hydro_Series_H80i_v2_Extreme_Performance_Liquid_Cooling_System
https://linustechtips.com/topic/901631-question-ryzen-7-build/
all ryzen 7 CPUs don't have an iGPU, you'll need a graphics card. you can get a 1700 and use the stock cooler if you're not overclocking.
https://linustechtips.com/topic/901631-question-ryzen-7-build/#findComment-11097416
39 minutes ago, ZEKENZY said:
You'd have to buy an R3 2200G or R5 2400G if you want Ryzen with decent onboard graphics
Or just buy the cheap 1800X with like a GT 1030 or RX 550
A 120mm AIO is not going to be much better than the $25 4 heat pipe tower coolers
https://linustechtips.com/topic/901631-question-ryzen-7-build/#findComment-11097478
which air cooler CPU can you recommend ?
https://linustechtips.com/topic/901631-question-ryzen-7-build/#findComment-11097485
if you get the 1700 then the stock cooler is fine. otherwise a cryorig M9a or deepcool gammaxx 400 will work if you aren't overclocking.
https://linustechtips.com/topic/901631-question-ryzen-7-build/#findComment-11097492
