Whenever there is a new update to my drivers, I can’t just download the drivers and update, I always need to remove the old version using DDU and only then install the new version, which takes a long time and it’s kind of annoying doing it every time.
is this normal? How do I fix it?
Side note: I don’t play anything while updating, I just watch YouTube or things like that while it’s updating.
https://linustechtips.com/topic/901346-problems-with-drivers/
Just now, Electronics Wizardy said:
reinstall the os, not the drivers.
What error do you get with a update?
It just stops in the middle, it gets to the part where it installs the drivers, but at around 25% it stops and tells me something went wrong.
https://linustechtips.com/topic/901346-problems-with-drivers/#findComment-11094462
