COOLER MASTER Elite 130 - Air flow Improvement
37 minutes ago, Rafael Fongozi said:
Wow many thanks. I'm new to overclock world, you know so I don't wanna mess with this... But I acutally wants to tell my board, do achieve 4.5ghz on the processor and the board does that for me by using the asus tuning profiles or changing some technical setting things that is needed to achieve that.
If you want your cpu to run at clocks speeds higher than stock, that's oc'ing.
Here's a good place to start:
4.5ghz isn't high at all and should be doable with a core voltage of 1.2v or less. Results may vary.
19 hours ago, Rafael Fongozi said:
Hello man, how are you? I have just a little doubt. If overclock my i5 8600k from 4.3 to 4.5 or more, will I ruin my intel warranty? Do you know something about it? Thank you again.
I'd like to second @WoodenMarker. I have nothing else to add to his post :)
I am doing well though! I hope you are as well! Feel free to reach out if you have any questions! :D
