Computer Lock Up Issues
Solved by Tzomb1e,
So as an update, in case anyone else comes across this issue, the problem turned about to be the second DIMM slot on channel B of my MOBO. I ended up ordering a replacement power supply which did not correct the issue (thankfully I could RMA this). I did further testing with each of my DIMMs and ended up only having the original issue with the before mentioned slot. I ordered a new MOBO and all issues and instability have been resolved.
