Radiator clearance in Fractal Design Define R6
Solved by Marinatall_Ironside,
18 minutes ago, W-L said:Your best option is to mock up the components to check for clearance before going any further. This will give you an idea of how much room you'll have.
https://overclock3d.net/reviews/cases_cooling/fractal_define_r6_review/6
Okay @Candren Lycosa refreshed my memory, and you can mount hard drives onto the panel that you can move to the back of the case, and you have unlimited clearance at the front panel.
