So I put together a system a few months ago so I could ascend to the level of pc master race. I had worked on some old pcs and even built a system for my parents so I felt fairly confident about this.
I built an A10-6800K with g skill 2133 memory and a 1tb toshiba 7200 rpm drive. Overtime I bought an Antec Kuhler 620, lg blu ray drive, and a card reader to fit in my fractal design core 1000 (seeing the budget?).
Evrything was working fir three months. Last night I found a 580 at Micro Center for $180 so I jumped at the chance. I knew my corsair 430m psu wouldn't be able to power the card so I picked up an EVGA 500b. Went home hooked everything up and no post. Fans running but screen is black. Checked all connectors. Tried a different monitor. Took everything apart. Remembered to disable the onboard graphics and I got it running. Turned it off to screw everything in place and got nothing when I tried to boot it again. Thought I might have shorted out the board so got a new one and breadboxed it today with just the cpu, stock heatsink, cpu power, and motherboard power. Tried it with both psu, a vga monitor, and a dvi monitor and nothing. Triple checked every connection and can't find out what's going on.
Any help?
    CPU - AMD 6800k; Mobo - ASRock FM2A88M-HD+; RAM G. SKill 8GB(2x4gb); GPU - NVIDIA GeForce GTX 580; Case - NZXT H230; Storage - Toshiba 1tb HDD, OCZ Agility 3 120 gb; Silverstone 600w 80+ bronze; Display - Dell 24 in., Generic 20 in.; Cooling - Antec Kuhler H20 620; Keyboard - Genereic Dell; Mouse - Logitech m510; Sound - Syba USB 2.0 DAC
https://linustechtips.com/topic/89966-another-no-post/
Any help?
Bent pins on the CPU possibly?
My Stuff! :D
My Stuff
  • Main Build - Soon to change due to it being dead
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 16GB Corsair Vengance  Blue LP 1600Mhz
  • 120GB Samsung 840
  • 2TB Seagate Barracuda
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • Bitfenix, Corsair, and Darkside cable extensions
  • Das Professional with Cherry MX Brown's & Custom Keycaps
  • 3x ASUS VS238H-P w/ Triple monitor mount in PLP
  • AudioTechnica ATH-M50's
  • Blue Yeti Microphone
  • TurtleBeach PX3 Wireless
  • Logitech C920 Webcam
  • Precision Audio Bookshelf Speakers
  • AudioSource AMP-100
  • Logitech G27 Racing setup
  • Laptop - Acer 7750G-9855
  • i7 2630QM
  • AMD 6650M GPU
  • 120GB Samsung 840 EVO
  • 8GB RAM
  • Operating System: Windows 7 Home Premium
  • Blu-ray Drive
  • Netbook - HP Pavillion DM1
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • Cell Phone - OnePlus One
  • 5.5-inch 1080p Screen
  • Qualcomm Snapdragon 801 processor @2.5Ghz
  • 13 Megapixel rear camera
  • 5 megapixel wide angle front facing camera
  • 3100 mAh non-removal battery
  • AC wifi
  • Cell Phone #2 - Nexus 5
  • 5 Inch 1080p Screen
  • Snapdragon 800
  • 8 megapixel rear camera
  • 1.3 megapixel front camera
  • 2300 mAh non-removable battery
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
  • 1x 1440 or 1600p Monitor
  • Das Mechanical Keyboard
https://linustechtips.com/topic/89966-another-no-post/#findComment-1216003
If that's the case then I recommend using a old credit card that you're not using and gently slide it between the pins to align them back.
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/89966-another-no-post/#findComment-1216010
Cpu wasn't moved until it was breadboxed on the new board.
https://linustechtips.com/topic/89966-another-no-post/#findComment-1216016
They might have gotten bent before you even put it in the board. Im not saying this is definitely the cause but I'd say it's worth checking.
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
https://linustechtips.com/topic/89966-another-no-post/#findComment-1216021
Ya. and there shouldn't be a problem with the new board.
https://linustechtips.com/topic/89966-another-no-post/#findComment-1216046
No post. no integrated.
https://linustechtips.com/topic/89966-another-no-post/#findComment-1216073
I'm assuming you don't post with out that 580?
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/89966-another-no-post/#findComment-1216118
Looks like you all might be right. Trying to remove thw cpu out of the new board and it doesn't want to come out. Suggestions on how to get it out?
https://linustechtips.com/topic/89966-another-no-post/#findComment-1216130
Scratch that. checked the pins. Look fine.
https://linustechtips.com/topic/89966-another-no-post/#findComment-1216195
Man I'm tired. Rechecked thw pins but this time it posted. Now I have to figure out what happened wirh the old board.
https://linustechtips.com/topic/89966-another-no-post/#findComment-1216293
