Looks like these MacBooks won't natively run Ubuntu (or any Linux) without heavy modification:
https://gist.github.com/roadrunner2/1289542a748d9a104e7baec6a92f9cd7
I'd say, if you need Ubuntu, run it in a VM.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/899068-problems-with-ubuntu/#findComment-11071823
feels bad huh
https://linustechtips.com/topic/899068-problems-with-ubuntu/#findComment-11071846
1 minute ago, reon-iwnl said:
feels bad huh
Keep in mind macOS is actually fully Unix compliant, so I'm not sure what would require you to run Linux next to it.
https://linustechtips.com/topic/899068-problems-with-ubuntu/#findComment-11071850
Well, stuff like hacking the os. You know, some people just wanna mess with their OS to a whole new level. Modding the windows registry or whatever macOS equivalent is not enough for these folks.
Sudo make me a sandwich
https://linustechtips.com/topic/899068-problems-with-ubuntu/#findComment-11077543
These folks should just run a VM then. If it's just the OS they want to mess with, why use a physical partition that can wreck your normal production OS. Plus, these folks shouldn't buy a Mac if they want that. Macs are historically bad at Linux support, except for the PowerPC stuff, that ran and still runs Linux like a champ.
https://linustechtips.com/topic/899068-problems-with-ubuntu/#findComment-11084329
Good point. I like to ask why people choose to build their own pc instead of just using a prebuilt that is guranteed to work?
https://linustechtips.com/topic/899068-problems-with-ubuntu/#findComment-11085041
