8 minutes ago, Hermann said:
Hey guys I was just wondering do I need both of the 4pin CPU connections to be plugged into my motherboard for the CPU to work properly or not. Can I just plug in one four pin connector?
I have an Asus X370 Pro
And a ryzen 1700x that will be overclocked
What PSU are you talking about?
But those two 4pin equal one 8pin and you should use them, especially if you plan to overclock.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/898726-psu-cpu-cable/#findComment-11068457
Going off the PCIE specifications I was looking at a while ago (and making some assumptions) I would say you should basically account for 18.75w per pin. So on a 4 pin that would be 75w, although I expect if you looked you would find the socket has addition power from the 24pin. Being as the TDP of the 1700x is 95w I would say don't do it.
If you're interested in a product please download and read the manual first.
Don't forget to tag or quote in your reply if you want me to know you've answered or have another question.
https://linustechtips.com/topic/898726-psu-cpu-cable/#findComment-11068511
