I was looking to buy the p4000 for my workstation, but the case doesn't have great dust filters so to avoid the process of cleaning the blower style cooler and making the system quieter decided to water-cool the gpu, now the problem is that im not into water loops and i already knew that there are brackets made by NZXT that allows to water cool with a all in one cooler, but i dont know if the bracket will fit, so someone already tried this?
https://linustechtips.com/topic/898580-quadro-p4000-cooling-solution/
What case do you have? Can you provide the link to the exact P4000? Also, how familiar are you with custom loops and water cooling in general?
The corsair spec omega,
This is the quadro i was talking about
http://www.pny.com/nvidia-quadro-p4000
And im not afraid to start a custom loop but i never done any
All Quadros uses the reference PCB spec depending on model. As for a full-coverage waterblock, there is none available. You can use an EK-VGA Supremacy, but you'll have to figure out a way to cool the MOSFETs and the GDDR5 memory ICs.
Edited by JurunceNK
Changed quote
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
So i could use a gpu only waterblock, does the alphacool waterblock https://www.aquatuning.us/water-cooling/gpu-water-blocks/gpu-full-cover/22491/alphacool-nexxxos-gpx-nvidia-quadro-m06-incl.-backplate-black work for that with some modding?
That's a full-cover block, and it will only work with the NVIDIA Quadro M5000.
When I said depending on model, I meant that the PCB layout is different from model-to-model (meaning the Quadro P4000 doesn't share the same layout as the P5000, P6000, etc. but the P4000 has only one layout), and each one of those models have only one PCB layout determined by NVIDIA.
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
Oh ok, so the gpu waterblock and the vrm and ram on passive cooling, rigth?
Yeah. You use the EK-VGA Supremacy (that's the only waterblock I can find that'll work for this card) to actively cool the GPU core, and you use thermal glue to glue on heatsinks on the GDDR5 ICs and MOSFETs to provide cooling.
But why would you want to go through the trouble of water-cooling the Quadro P4000 to begin with?
Edited by JurunceNK
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
I prefer to clean a radiator rather than the card itself and im more afraid to loose any screws opening the card than having leaks or cleaning a water loop
