need help with python
FreakBeta
Go to solution Solved by MyName13,
7 hours ago, FreakBeta said:
First thanks for read this.
I'm new in this of programming and a want to creat a game with python, but i don't know where to start.
when i search on google or youtube i dont find anything than help me, everything i found does not explain
what is for example variables or it does, probably i need to star in the botton of programming, pls help
sorry if my english is bad, i'm from chile so i.m making the best i can
thanks for everything
After learning Python, you could use Pygame or Pyglet.
if you don't know what a variable is then you need to learn the basics of programming before you attempt a game
codecademy is good for learning syntax and as a starting point
Join the Appleitionist cause! See spoiler below for answers to common questions that shouldn't be common!
Q: Do I have a virus?!
A: If you didn't click a sketchy email, haven't left your computer physically open to attack, haven't downloaded anything sketchy/free, know that your software hasn't been exploited in a new hack, then the answer is: probably not.
Q: What email/VPN should I use?
A: Proton mail and VPN are the best for email and VPNs respectively. (They're free in a good way)
Q: How can I stay anonymous on the (deep/dark) webzz???....
A: By learning how to de-anonymize everyone else; if you can do that, then you know what to do for yourself.
Q: What Linux distro is best for x y z?
A: Lubuntu for things with little processing power, Ubuntu for normal PCs, and if you need to do anything else then it's best if you do the research yourself.
Q: Why is my Linux giving me x y z error?
A: Have you not googled it? Are you sure StackOverflow doesn't have an answer? Does the error tell you what's wrong? If the answer is no to all of those, message me.
first thanks for answer so fast.
but i need to pay to learn in codeacademy, after they explain the basics of a lenguage then i have to pay go on.
you know other page than can help me
google.com and stackoverflow.com are literally the two most useful websites for any programmer.
As for python resources specifically, the wiki has a pretty good list: https://wiki.python.org/moin/BeginnersGuide/Programmers
Current LTT F@H Rank: 69    Score: 3,457,572,143    Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 3900X w/PBO on
Cooler: Noctua NH-D15
Mobo: Asus X470-F Gaming
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 6.12.4
CPU: Ryzen R7 2700x @ Stock
Cooler: Noctua NH-U9S
Mobo: Asus Prime X470-Pro
RAM: 16GB G-Skill Ripjaws V + 16GB Hyperx Fury Black @ stock
PSU: EVGA G3 850W
SSD: Samsung 980 Pro 1TB NVME, Samsung 970 evo plus 1TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (3x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
I think Chile has a free trade agreement with the US. I have an extra copy of a book called Starting Out With Python that I could try to ship you if the rate isn't outrageous. Of course, the book is in English.
ENCRYPTION IS NOT A CRIME
you apparently need the basics if you don't know what a variable is, take what you can get
