زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/897087-help-a-computer-noob/#findComment-11051693
The first thing I do with a new system is install drivers. You'd want to get drivers for your GPU and motherboard, mainly.
Next, I usually run a benchmark or two to make sure my PC is running as well as it should. Unigine Superposition and Heaven are good ones. Aida64 is good for testing various other areas of your system. I like to use MSI Afterburner to monitor my GPU temperatures and frequency(also helps you overclock).
For the CPU, most people use CPU-Z(unless I'm mistaken) to monitor that.
Welcome to the forums!
https://linustechtips.com/topic/897087-help-a-computer-noob/#findComment-11051700
install some drivers, get SpeedFan installed to control the fans, and install steam ofcourse!
https://linustechtips.com/topic/897087-help-a-computer-noob/#findComment-11051705
17 minutes ago, Legendarypoet said:
Eiffel65
Is it blue????
My main desktop, "Rufus":
PC Specs:
CPU: AMD Ryzen 5 1600
CPU Cooler: Cooler Master MasterLiquid Lite 120
RAM: 2x8gb Corsair Vengence DDR4 Red LED @ 3066mt/s
Motherboard: MSI B350 Gaming Pro Carbon
GPU: XFX RX 580 GTR XXX White
Storage: Mushkin ECO3 256GB SATA3 SSD + Some hitachi thing
PSU: Seasonic Focus Plus Gold 650W
Case: Corsair Crystal 460X
OS: Windows 10 x64 Pro Version 1607
Retro machine:
PC Specs:
CPU: Intel Core 2 Quad Q9550
CPU Cooler: Stock heatsink
RAM: GSkill 4gb DDR2 1066mt/s
Motherboard: Asus P5n-e SLI
GPU: 8800 GTS 640mb, I swap between that and my 8800 GTS 512mb
Storage: Seagate 320gb right from 2006
PSU: Ultra 600W
Case: Deepcool Tesseract SW
OS: Windows XP SP3 32-bit, Linux Mint 18.2 Cinnamon 64-bit, Manjaro Deepin x64 (sorta)
Mac Pro Early 2008: Dual Xeon X5482s w/ 32GB RAM & HD 5770 running macOS High Sierra
More PC's
https://linustechtips.com/topic/897087-help-a-computer-noob/#findComment-11051757
Just now, userzero said:
No it's da ba dee.
Dangit. You make me feel so blue :(
PC Specs:
Retro machine:
PC Specs:
PSU: Ultra 600W
More PC's
https://linustechtips.com/topic/897087-help-a-computer-noob/#findComment-11051778
15 minutes ago, BuddyDevv said:
In core temp 6 of my 8 cores are just under 3k freq but 2 of them are 5.2k?
Weird. XFR turbos don’t always read right in those programs.
PC Specs:
Retro machine:
PC Specs:
PSU: Ultra 600W
More PC's
https://linustechtips.com/topic/897087-help-a-computer-noob/#findComment-11051936
