Fans Stuck at 100% According to ears, software says 0-8%,
Slurpy
NOTE: I AM RUNNING THIS WITH A GTX 1070 FROM ZOTAC
I am using a GTX 1060 3GB in my system to help while playing vr+other GPU intensive tasks.
However, the 1060 is really loud, even when under no load and fans are manually set to 0 in GPU tweak/Firestorm
Help M8
Main Laptop: Google Pixelbook
Dev mode w/ Cross Enabled
PC: Ryzen 7
1700x / 32GB 2667 / GTX 1080 / 1.5 TB of SSDs / 1TB of HDDs
Monitor: AW3418DW Ultrawide
120hz / 3440x1440 / RGB / Amazonbasics Dual Monitor Arm
2nd Monitor: Dell U2515hx
25 inches / 1440p / Portrait / Amazonbasics Dual Monitor Arm
more info on when and how it started? I believe it wasn't like this when it first arrived.
Try to use dedicated software no 3rd party manuals reset everything reroll a driver version if needed to, see if they still do it.
