So from times to times without doing anything specific i get this error:0x000000D1 DRIVER_IRQL_NOT_LESS_OR_EQUAL also with pci.sys. After that the computer starts again and it loads normally but i happens again and again. Any suggestions on how to fix it? Any help will be appreciated.
https://linustechtips.com/topic/896147-blue-screen/
It's a driver issue. Make sure your drivers are all up to date.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/896147-blue-screen/#findComment-11041402
Could you run some kind of program that verifies your drivers are all working correctly and that you have he right ones. Not my area of expertise unfortunately but I'm sure there is a program for this and it should pinpoint the driver that's causing the problem..
I'm sorry I can't be more helpful but it is at least a starting point for you.
https://linustechtips.com/topic/896147-blue-screen/#findComment-11041416
