Best Monitor under 250 Dollars?
Drkrinklez
I have a gtx960, and I'm looking for a new monitor with the budget listed above. Any recommendations? Looking for small bezzles.
what res?
what are you doing?
I usually just always recommend 4k and lower refresh rate regardless i suppose. Did the whole 160hz thing in the early 2000's and was nothing special.
I guess just anything 4k 60hz is what i'd recommend. pretty much just skip 2k and 1080 these days no reason to go back.
18 minutes ago, emosun said:
what res?
what are you doing?
1080p, playing games like escape from tarkov, arma 3, battlfield 1, minecraft, csgo...
With such low requirements you might be able to just find a used monitor locally that should be able to do that.
I know your budget is 250$ but honestly you shouldn't have to pay over 100$ for just a 1080p monitor these days.
I was thinking of a IPS monitor, along with perhaps 144hz
