Mixing 4k and 1080 hd monitors
marksmanguy
Hi, I currently have a 3 monitor setup in 1080. I would like to upgrade to 4k but that is a pretty expensive move to do all at once. Can i upgrade just one to 4k? It is mainly for work and do not game on the 3 monitors at once.
Have 2 x 1080ti and use windows 7.
Thanks a lot!
-Alex
Yes I believe you can mix and match.
Ya it shouldn't really make a difference. I would just make the 4k one your primary monitor. You shouldn't have any performance issues either.
Yes, just like with any other monitors you can.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
But will there issues with scaling? Or is that kind of stuff all sorted out?
You'll soon find out.
Windows will take care of the scaling automatically for you.
Probably gaming or helping technophobes with tech...
The only issue you could have is if you need to increase the fonts on windows, because it should changes it for all the screens, making the 1080p like a 720p.
Also keep in mind the big resolution difference in everyday use. I have a 1440p near a 1080p, but I'm using the 1080p only when I need bigger fonts, because when the two screens are near eachother the difference is really too noticeable. In your case it's even more.
Just keep this in mind.
Latest build: MyPC Liquid Time
