Is there a way i can clean the Cherry MX reds switches on my machenical keyboard. i mean the actual switches inside... i spilt about 300ml of coke on the keyboard, dried it completely and made sure it works... no shorts so thats all good. now i need to get rid of the stickiness inside some of the switches (thank goodness its only on some keys).
Saw a video of a guy suggesting that i hold down a the switch with some poking tool like a screw driver and pour hand sanitizer in there but i dunno. i was thinking maybe isopropyl alcohol will do the trick?? just pour a bit of alcohol in and repeatedly press the switch to get it where it needs to go, then leave it to dry for a few days...
Any other safer suggestions before i go and probably destroy my K95?
https://linustechtips.com/topic/895330-cleaning-machenical-switches/
just pour alcohol into it and press the switch a bunch then wait an hour alcohol dries super fast
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
6 minutes ago, Pangea2017 said:
Hand sanitizer is isopropanol. I don't know if this is a good solvent for sugar. Try it first. As alternativ start with H2O and after this Isopropanol.
Isopropyl alcohol is an alcohol solvent. and its easy to clean P stuff with coz it evaporates at room temps.. so it doesnt leave and residue behind. what i wanna know is it okay to stick down into my switches. And getting my hands on pure H2O is gonna be a nightmare. i outlive in USA where you can buy guns at the same place you buy your pants... and nothing less than pure H2O is not going anywhere near my keybaord
isopropyl alcohol. pour it on the switch and press it until your heart desires.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
  • 3 weeks later...
On 2/11/2018 at 7:08 PM, geo3 said:
I wouldn't pour anything into the switch. See if you can open them. Then use a cotton swap to clean inside and be very careful not to bend the metal contacts.
:-P too late... poured into the switches, actually turned out quite well. it did what i wanted it to do. just use a syringe while pushing down the switch with a screwdriver to pour a small amount of alcohol and press the key vigorously. then leave the switches to dry for a while. i left mine under some display spot light i have in my room for a few hours and then let it evaporate naturally coz it was a bit cold at the time and i am lazy (the longer the safer basically) for about 2 days then when i plugged in my keybaord, it worked perfectly again :-)
Just dont over do it with the alcohol, like just a very small amount, like we talking milliliters here. i think it was about 2ml?? but very small. but then it also depends how bad it is inside the switch so start out a tiny bit and add a lil more until it feel smooth again.
