Ive just installed an AIO watercooler into my Lian Li Pc V351 and now i keep getting clock speed drops on my I5 2500k. I asssume this is due to a lack of airflow on the VRM's causing it to overheat.
Any good solutions for a really small case? the AIO has helped my CPU temps alot, and gives a much higher boost frequency, but the VRM's overheating is my only problem.
Also, my board doesnt seem to be regognising that i have an unlocked chip, as i cant adjust the turbo frequency and i can only put the clock ratio up to 33, its an asus board, cant remember the full title.
Any help on either issue would be incredible!
Many thanks
Sam
https://linustechtips.com/topic/895012-vrm-cooling-small-case/
Many thanks
Sam
Just add airflow the the VRM, Small case.. then use a small fan... just get airflow on that heat sink
https://linustechtips.com/topic/895012-vrm-cooling-small-case/#findComment-11039145
21 hours ago, Samfazzer said:
Asus P8H61-M is the motherboards name
The H61 chipset cannot overclock via CPU multiplier.
The LGA 1155 socket (including your i5-2500K) requires a P67, Z68, or Z77 motherboard to do that.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/895012-vrm-cooling-small-case/#findComment-11039323
