Hi, I recently gained interest in pc gaming, I used to be a console peasant, but after I started playing CSGO and dota, I have changed, I have around $2500 to spend to build a gaming pc for most MOBA and FPS games. Please help me build a pc (no need monitors,keyboards,mouse and headsets)
https://linustechtips.com/topic/893093-help-me-build/
$2500 for MOBA's and FPS games seems kinda excessive, which monitor are you using? which country?
https://linustechtips.com/topic/893093-help-me-build/#findComment-11009638
$2500 should build you a solid PC, but you don't state what resolution - still for this price you should be looking at 4k imo
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($364.79 @ SuperBiiz)
CPU Cooler: NZXT - Kraken X62 Rev 2 98.2 CFM Liquid CPU Cooler  ($147.49 @ SuperBiiz)
Motherboard: Asus - ROG STRIX Z370-E GAMING ATX LGA1151 Motherboard  ($189.99 @ Amazon)
Memory: Corsair - Vengeance RGB 16GB (2 x 8GB) DDR4-3600 Memory  ($229.99 @ Amazon)
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive  ($227.79 @ OutletPC)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($44.89 @ OutletPC)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB SC Black Edition Video Card  ($1199.78 @ OutletPC)
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case  ($79.99 @ Amazon)
Power Supply: Corsair - RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.98 @ Newegg)
Total: $2564.69
Generated by PCPartPicker 2018-02-04 06:56 EST-0500
now GPU's are stupid price at the moment, you may find a 1080TI for less - I'm in the UK the GPU hike isn't quite so bad over here, if you do get a 1080ti for normal money, then I would swap out the 1TB HDD for a 1 TB SSD
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/893093-help-me-build/#findComment-11009649
depends on ur monitor... u cant put a 1080ti super overclocked , rgb , enviromental friendly , made of gold , water cooled , 12 rgb fans, with x ray tech , and a certificate that it can run crysis , when you have a monitor of 1080 p .. u catchin my drift ?
https://linustechtips.com/topic/893093-help-me-build/#findComment-11009667
Need information on monitor(s) to properly select gpu.
https://linustechtips.com/topic/893093-help-me-build/#findComment-11012068
CPU: Intel - Core i7-8700 3.2GHz 6-Core Processor  ($312.00 @ Amazon)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($34.89 @ OutletPC)
Motherboard: Asus - Prime Z370-A ATX LGA1151 Motherboard  ($159.99 @ SuperBiiz)
Memory: G.Skill - Ripjaws 4 Series 16GB (2 x 8GB) DDR4-3000 Memory  ($164.99 @ Newegg)
Storage: Crucial - MX500 1TB 2.5" Solid State Drive  ($259.79 @ OutletPC)
Video Card: MSI - GeForce GTX 1080 Ti 11GB GAMING X Video Card  ($904.98 @ Newegg)
Case: Fractal Design - Meshify C ATX Mid Tower Case  ($86.99 @ SuperBiiz)
Power Supply: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.59 @ SuperBiiz)
Total: $2003.22
Generated by PCPartPicker 2018-02-05 16:59 EST-0500
https://linustechtips.com/topic/893093-help-me-build/#findComment-11015004
