RAM unstable @3200hz, please help!
1 hour ago, MageTank said:Memory manufacturers do not test ram on every possible motherboard that is released. Each and every motherboard has a different trace topology that impacts the signaling of the ram. They typically validate the ram itself, then leave it up to the board manufacturers to validate memory on their specific boards. This is why each motherboard has a QVL list.
All that being said, I do agree with you that it's likely not his board. The board itself is rated for 4133mhz+, and I've seen people clock to 4333 on that specific board just fine in a 1DPC setup with single rank sticks. It's more likely that either his CPU's IMC is a dud, or he needs to change the DIMM slots his ram is located in, for better signaling (slots 2 and 4 preferred).
@jefftm95 Care to link your memory kit to me? I am curious as to how many sticks you are using, and whether or not they are dual rank or single rank. There could be some issues with tertiary timings holding you back, and it may even be a simple fix.
thanks sexy
