What cases would you guys recommend, I am looking to do a large water cooling loop with possibly 2 graphics cards. Nothing about this build is finalzed but was wonder what you guys would recommend for a case. (Taking all recommendations)
ATX/EATX
High End MoBo and CPU
Large Water cooling Loop
Possibly 2 Graphics cards
Just curious as to what you guys think, I was looking at Phanteks Enthoo Elite or possibly a desk build
Thanks
https://linustechtips.com/topic/892367-case-recomendations/
Well, I mean if you can afford that level of case, it's kinda hard to beat
Desk PC's are super cool, but they're the least feasible of case options since they're the hardest to move and maintain usually. However if you're going anywhere anytime soon, you can always go that route fro sure!
https://linustechtips.com/topic/892367-case-recomendations/#findComment-11003997
It comes down to the person style and taste really,Some like a simple looking case like a define r6.And some want a water cooling master piece and get a core p5 or p7 you know the open frame glass box kinda case.With a big budget it really comes down to your taste which way you want to go with a case.My next build will probably be in a lian li 011 dynamic.Its a dual camber case and the pretty stuff is in a 2 sided glass box lol.
https://linustechtips.com/topic/892367-case-recomendations/#findComment-11006047
On 2/2/2018 at 8:43 PM, xXCapAwesomeXx said:
Awesome, thanks for the input and ideas so far, its nice to have people to bounce things off of @TVwazhere @andrewmp6
If you have the time, patience and DIY knowledge, you could also build your own desk PC, often times it can come out really exceptional if you plan it right
https://linustechtips.com/topic/892367-case-recomendations/#findComment-11013210
