Hey guys I have a $5000 budget for a stream and editing rig. I know this is a bit extreme but I planned the build to last 5 to 6 years. The build is for my local high school who already has a big sever for storing their data so this only has to edit and stream for them. Thank you for any feedback.
https://linustechtips.com/topic/890217-edit-and-stream-machine-help/
Looks crazy overkill lol I think that’s great if money isn’t a problem
Wait... - why a capture card? At this good of a system, the system itself is enough.
PCPP link? I'd change some things.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
I would suggest a number of different part choices.
An NH-U14S is an excellent cooler with no clearance limitations on most LGA 2066 motherboards.
A motherboard that uses heavy duty components.for improved longevity even in high duty environments.
Faster memory. The cpu memory controller stock speed is DDR4-2666.
A simpler storage scheme. The budget allows for a 1TB NVMe M.2 drive. Faster storage performance will improve performance in some editing tasks and when streaming. The Pro version is designed for heavier duty environments. The drive can be split into logical volumes if needed. An alternative would be a 1TB or 2TB Samsung 860 Pro SATA III ssd.
A case that I believe is better suited to the environment. No protrusions. Steel and aluminium construction. Designed for quiet operation.
A more efficient psu. It is not much more than an 80+ Gold unit.
CPU: Intel - Core i9-7900X 3.3GHz 10-Core Processor  ($969.99 @ Amazon)
CPU Cooler: Noctua - NH-U14S 55.0 CFM CPU Cooler  ($63.69 @ Newegg)
Motherboard: Asus - TUF X299 MARK 1 ATX LGA2066 Motherboard  ($327.53 @ Newegg Marketplace)
Memory: G.Skill - Trident Z 32GB (4 x 8GB) DDR4-3200 Memory  ($359.99 @ Newegg)
Storage: Samsung - 960 Pro 1TB M.2-2280 Solid State Drive  ($623.99 @ SuperBiiz)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB SC2 Video Card  ($1349.99 @ Newegg Marketplace)
Case: Fractal Design - Define R6 Black ATX Mid Tower Case  ($129.99 @ SuperBiiz)
Power Supply: SeaSonic - FOCUS Plus Platinum 850W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($139.90 @ Amazon)
Total: $3965.07
Generated by PCPartPicker 2018-01-27 00:40 EST-0500
