How much heat does overclocked RAM add?
40 minutes ago, stateofpsychosis said:It's typically around 1.5v
For standard speeds it is (1333-1600MHz), and for high speed DDR3 1.6-1.65v is also typical.
AS you said before, IMCs generate more heat as you use faster RAM. They will also be harder to keep stable when OCing the CPU, so a stable CPU OC with 1600MHz may not be as stable, and certainly not as cool, once you tune RAM to its XMP (and 2400 is almost the ceiling for DDR3, with very few exceptional kits shipping with a faster XMP).
5 minutes ago, stateofpsychosis said:Should I be doing it separately from the CPU overclock?
I mean, should I only overclock and stress these one at a time and not both at once?
Sort of. You want to keep one of them (typically RAM) fixed while you play with the other, and once you have a satisfactory result, do a final round of tuning with RAM at the desired speed.
Don't know in Haswell, but in AMD that final step often involved messing with the CPU-NB voltage, rather than Vcore.
