overheating Overheating Issues, At Wits End
On 6/1/2024 at 11:34 PM, Shimejii said:i use fan control (its an app) and manually control my fans for my aircooler. I generally keep it at 50% at idle, then 75-100% during workloads depending on if its gaming or a video render. Id recommend that route and see if you can get the result you want.
You may have to also undervolt and really go over the bios to make sure its just not pumping too much voltage.
Turns out the issue was indeed just the cooler. I know this is really late as a reply but I spent the last few days ordering an NH-D15 and installing it. Running stress test now and "Doo doo head" went from the 91Watts draw at 100C at 4.1mhz to 180-190watts at 70C at 5.5mhz. I had no idea a cooler could make such a big difference especially since they are right around in the same ballpark in terms of size and even more so that the dark rock has an additional fan, I would have thought for sure it was in the favor of the dark rock.
Thanks again for your help though, much appreciated!
