Its fine except that PSU is major overkill, unless you plan on buying more qaudro's/hard drives and need the upgrade space.
I would rather agree on what we share, than fight on what we don't. - Myself
FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/
https://linustechtips.com/topic/888907-workstation-build/#findComment-10967033
What specific applications are you looking at?
Why 2x16gb RAM and not 4x8gb? You could also probably save some money on cheaper psu, case, ram, etc. and then get a better GPU
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/888907-workstation-build/#findComment-10967036
What programs are you referring to?
For better stability, you should go with a single ram kit instead of separate sticks that aren't guaranteed to work together.
The case is excessively large. A smaller case could be cheaper and provide more efficient cooling.
The psu is overkill. A good 600w would be plenty already.
The Builds Logs subforum is for showing off a completed build or the process of doing so.
Moved to New Builds and Planning.
https://linustechtips.com/topic/888907-workstation-build/#findComment-10967042
I'm looking at programs such as Adobe CC, blender, and Autocad
https://linustechtips.com/topic/888907-workstation-build/#findComment-10967043
I'd:
  • Get a TR cooler, not just some random one
  • Get a different RAM set up
  • I would get a more modern case
  • Your PSU is massive overkill
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/888907-workstation-build/#findComment-10967045
7 minutes ago, dizmo said:
I'd:
Would this be an improvement?
https://pcpartpicker.com/user/josephk545/saved/TcsCyc
https://linustechtips.com/topic/888907-workstation-build/#findComment-10967073
Out of those Autocad prefers single threaded performance, blender prefers multi, and Adobe is a bit of a mix. Do you do blender or autocad more? Depending on which, a 7900x or 1950x may be a better choice.
As well, after doing some research, it seems like a Quadro isn't really worth it for you. It definitely doesn't matter for Adobe and iirc not for blender either. Quadros only make a big difference in some CAD applications and from some quick searching it seems like AutoCAD is not a program that doesn't like GeForce cards.
CPU: AMD - Threadripper 1950X 3.4GHz 16-Core Processor  ($839.99 @ Amazon)
CPU Cooler: Noctua - NH-U14S TR4-SP3 140.2 CFM CPU Cooler  ($79.90 @ Amazon)
Motherboard: Asus - ROG ZENITH EXTREME EATX TR4 Motherboard  ($479.89 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 32GB (4 x 8GB) DDR4-3000 Memory  ($349.99 @ Newegg)
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive  ($139.99 @ B&H)
Storage: Western Digital - Gold 10TB 3.5" 7200RPM Internal Hard Drive  ($387.99 @ SuperBiiz)
Video Card: Asus - GeForce GTX 1070 8GB Dual Series Video Card  ($799.89 @ OutletPC)
Case: Fractal Design - Define R6 Blackout TG ATX Mid Tower Case  ($164.98 @ Newegg)
Power Supply: SeaSonic - FOCUS Plus Gold 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ SuperBiiz)
Operating System: Microsoft - Windows 10 Pro OEM 64-bit  ($138.89 @ OutletPC)
Total: $3481.50
Generated by PCPartPicker 2018-01-22 20:36 EST-0500
Unfortunately, due to the RIDICULOUS pricing of GPUs right now thanks to miners (cards are about DOUBLE what they normally are) you're paying A LOT for a 1070, but it's still better than a P1000
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/888907-workstation-build/#findComment-10967095
Total: $3481.50
I typically use Blender more. Also I might be able to get a GTX 1080 from a friend at a cheaper price since he's filthy rich anyway. Thanks for the advice!
https://linustechtips.com/topic/888907-workstation-build/#findComment-10967103
24 minutes ago, josephk545 said:
Yeah looks better, though I'd try and get faster RAM. I'm pretty sure TR is like Ryzen and prefers higher speeds.
You can also get a liquid cooler. Enermax makes a really solid AIO for TR.
The 750D is still pretty old. I'd really try and get something with tempered glass if you want a window, acrylic has a tendency to scratch.
https://linustechtips.com/topic/888907-workstation-build/#findComment-10967169
Do you only use cpu rendering? I ask because Blender can use multiple gpu for the task and generally renders faster when it does.
What sort of budget do you have for the the system, excluding peripherals.
51 minutes ago, josephk545 said:
Threadripper cpu support quad channel memory operation. For optimal performance one should use quad channel (i.e. 4 memory module) memory kits.
One should have sufficient ssd storage for all active projects and scratch needs. If budget permits, one might even consider an NVMe drive.
The Windows 10 OEM license does not permit use in a DIY build. One needs to buy a retail version.
https://linustechtips.com/topic/888907-workstation-build/#findComment-10967278
So if i can, I should use an NVMe m.2 drive instead of a traditional SSD
https://linustechtips.com/topic/888907-workstation-build/#findComment-10967307
Only presuming there is budget available that would not be better spent elsewhere. An NVMe M.2 can offer a performance improvement in some tasks.
https://linustechtips.com/topic/888907-workstation-build/#findComment-10968056
