Cpu cooler HELP!
Go to solution Solved by Damascus,
It will work, all intel 115x have the same mounting.
6 minutes ago, Ervinoo said:
Hey guys, im thinking of purchasing a new cooler for my 7700k, and i was wondering if the ARCTIC Freezer 11 LP would fit my 1151 motherboard (H110M-R)
Thanks!!!
According to Amazon it's compatible with LGA 1150, 1155, 1156 & 775 only.
Ryzen 5 1500X @ 3.9GHz On 1.3625V | MSI B350M Gaming Pro | 16GB G.Skill Ripjaws V DDR4 3200MHz | 3GB MSI GTX 1060 Gaming X 2063MHz Core 9408MHz Mem | EVGA G2 550W | 250GB Samsung 850 EVO | Windows 10 Home 64-bit Version 1903 (Build 18362.295) | MasterCase Pro 3
https://linustechtips.com/topic/888098-cpu-cooler-help/#findComment-10958583
Are you set to using that cooler? There are better performing low-profile coolers. They are more expensive and might not be available for you. But 7700K is known as hot chip.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/888098-cpu-cooler-help/#findComment-10962126
