I get 1 short beep with a 1 second pause then 2 short beeps. the mobo is a Asus P5LDZ SE
-edit and another problem is the fan when you plug it in it just ramps up to the max speed and stays at it. and it wont slow down when i turn the speed nob. The fan is a old ThermalTake with a Thermaltake VR Fan Speed PCI controler
Desktop: CPU: I7-5820K GPU: 980Ti, 750Ti PhysX Mobo: MSI X99A SLI PLUS RAM: 4x4 Kingston DDR4 2400MHz OS: Win10
Storage: 250GB Samsung Evo, 3TB WD Black and Green FIRESTRIKE, Reason for dedicated PhysX Card.
Peripherals: Screen: 3x BenQ VZ2350 Mouse: Razer Naga Keyboard: Some Dell Thing Sound: Razer Tiamat, 5.1 Logitech Surround Speakers
https://linustechtips.com/topic/88802-trying-to-fix-old-comp-please-help/
Issue with memory?
8320 @ 4.3ghz l Gigabyte 970a Ud3 l Hyper 212 Evo l R9 290 l 8gb RAM 1866 Vengeance l 1tb WD Black l 120gb Samsung Evo SSD l HX750 Gold PSU l 500d Arctic Case l Windows 8 OS l K65 and Blackwidow Keyboard l M65 and DeathAdder 2013 l Qck Steelseries l 24in Vizio Monitor 1080p
i can try taking the GPU out but wont be able to see any thing cause i only have a conecter for DVI and VGA not the big purple thing on the mobo xD
Main: AMD Athlon X4 750K| Coolermaster Hyper TX3 EVO | Gigabyte GA-F2A75M-HD2 | 8GB Kingston 1333mhz | WD Caviar Green 1tb | Coolermaster N200 | OCZ coreXstream 500w | Sapphire Radeon HD 7850 2GB | |Kingston 3k ssd 128gb |
i got it started :D just desided to work
still got the beeps tho but its working now
still have the problem with the fan tho
Seems like a ram issue to me. You sure caps on the motherboard are fine, any of them look slightly larger or are leaking then its a gonna
Listen if you care.
