Hey guys. I need to create a batch script that creates some directories, like this:
2018
    January
        1
        2
        31
    February
        1
        2
        3
2019
    January
        1
        2
        31
    February
        1
        2
        3
20XX
Unfortunately, I have to do this on Windows in a batch script. If I were using bash, I'd do this:
#!/bin/bash
if [[ $# -ne 2 ]]; then
    echo "Usage: $0 [StartYear] [EndYear]"
    echo "Ex: $0 2018 2050"
    exit 1
fi
NUMERIC_REGEX="[0-9]{4}"
MONTHS="January February March April May June July August September October November December"
startYear=$1
endYear=$2
if [[ ! "$startYear" =~ $NUMERIC_REGEX ]]; then { echo "\"$startYear\" is not a valid 4 digit year"; exit 1; } fi
if [[ ! "$endYear" =~ $NUMERIC_REGEX ]]; then { echo "\"$endYear\" is not a valid 4 digit year"; exit 1; } fi
if [[ $endYear -lt $startYear ]]; then { echo "EndYear must be greater than or equal to StartYear ($endYear < $startYear)"; exit 1; } fi
for (( year=startYear; year<=endYear; year++ )); do
    for month in $MONTHS; do
        for (( day=0; day<=31; day++ )); do
            targetDirectory="$year/$month/$day"
            mkdir "$targetDirectory" || { echo "Could not create directory \"$targetDirectory\", exiting"; exit 1; }
        done
    done
done
So example usage would be "PROGRAM_NAME.bat 2010 2015" and it would generate the folder structure for 2010 to 2015. Note that the goal is NOT to only create ex 28 folders in February, but to simply make 31 folders for every month. If the regex can't be translated to a batch script, that's fine. I'm more interested in how to convert this to a batch script, and I was hoping a batch expert could get me started.
Thanks.
https://linustechtips.com/topic/887349-simple-batch-script-help/
Since you're not that familiar with windows batch scripts, I would say instead of using nested loops, just create several different batch files.
First batch file one takes as arguments a beginning year and ending year and the directory to put them all in (or instead of arguments, store them in variables inside)
Write a loop, starting at the first year until you get to the last year.
For each year, create a directory with that year, then pass that directory, and the year to the second batch file.
In the 2nd batch file, for each month, pass the year directory name, the month, and the year to the 3rd batch file.
In the 3rd batch file, create a directory with that month name
Determine the number of days in that month (check for leap years)
Loop and create a directory for each day.
Thanks, but I want to keep this confined to one script.
On 1/19/2018 at 1:38 AM, geo3 said:
Can you use powershell? It's way more  powerful and easy to use than a batch script. You can use a more C like syntax and you have direct access to create and manipulate .net objects.
Unfortunately, I have to run this on Windows XP and Windows 2000 systems, so PowerShell is a no-go.
Okay, I figured it out. The (rough) translation of the shell script to Batch looks like this:
@ECHO off
set argC=0
for %%x in (%*) do Set /A argC+=1
if %argC% NEQ 2 (
    echo Usage: %0 [StartYear] [EndYear]
    echo Ex: %0 2018 2050
    EXIT /B 1
set startYear=%1
set endYear=%2
echo %startYear% | findstr "^[-][1-9][0-9]*$ ^[1-9][0-9]*$ ^0$">nul
if %ERRORLEVEL% EQU 0 (
    echo "%startYear%" is not a valid 4 digit year
    EXIT /B 1
echo %endYear% | findstr "^[-][1-9][0-9]*$ ^[1-9][0-9]*$ ^0$">nul
    echo "%endYear%" is not a valid 4 digit year
    EXIT /B 1
if %startYear% GTR %endYear% (
    echo EndYear must be greater than or equal to StartYear "(%endYear% < %startYear%)"
    EXIT /B 1
set months=(January February March April May June July August September October November December)
for /l %%y in (%startYear%,1,%endYear%) do (
    for %%m in %months% do (
        for /l %%d in (1, 1, 31) do (
            mkdir %%y\%%m\%%d
                echo Successfully created directory %%y\%%m\%%d
            ) else (
                echo Could not create directory %%y\%%m\%%d, exiting script
                pause
                EXIT /B 1
2018
    January
        1
        2
        31
    February
        1
        2
        3
2019
    January
        1
        2
        31
    February
        1
        2
        3
20XX
#!/bin/bash
    exit 1
fi
startYear=$1
endYear=$2
        done
    done
done
Thanks.
try going into addremove programs
then add components
see if BASH is listed(win10 has support for bash functionality)
then add components
Unfortunately, I have to run this on Windows XP and Windows 2000 systems, so WSL Bash is a no-go.
try looking up building calendar in c64 basic then
this may give some nice tricks
also look at schoolfreeware youtube as the have a number of vids(i watched big chunk of c64 vids and think array linking/mergeing be helpful here as your batching)
also anything under dos would help as again batch is used(grab dos calender or old dos spreadsheet that has calender)
