HI all, Im looking for some help when finding a laptop for use with a small amount of gaming and small to medium workstation applications like revit.
This are what i want in the laptop
- geforce nvidia 1050ti
- 16gb of ram
-fhd screen (1920x1080
- 2 hard drives (e.g 1 256gb ssd and 1tb hdd)
- battery life of at least 6 hours.
I'm not very tech savvy, so explain this stuff to me in simple terms! Also i would prefer not to go with a gaming themed laptop just because of how people would look at me while im using it at uni. Thank you very much!
https://linustechtips.com/topic/886515-finding-a-laptop-need-help/
budget?
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
- 16gb of ram
If it fits your budget look at the Acer Predator Helios or Dell inspiron 7000 or Acer v15,...
Kind of depends on where you are from to here in Belgium most of these cost a lot more than in the USA for instance so if you want to cut the cost go for cheaper dell 7567 and just add a stick of 8gb ram or something like that :)
Desktop
CPUi5-6600K MotherboardGigabyte GA-Z170-HD3P CPU Cooler: Thermalright True Spirit 120M Black/white RAM: Corsair Vengeance LPX 16 GB DDR4 2400Mhz GPU: Gigabyte 1070 HDDs: 2 x Seagate Barracuda 2TB 7200 RPM  SSDSamsung EVO 850 500GB PSU: Coolermaster 550W 80+ Gold Case: NZXT S340 (White) with a white led strip ;)
Laptops
Dell 7577
CPUi7 7700HQ RAM: 16 GB DDR4 2400Mhz GPU: GTX1060 Max-q HDD: 1TB 5400 RPM  SSDNVMe 512GB SCREEN: 4k IPS 15.6"
Macbook pro 2018
CPUi7 RAM: 16 GB DDR4 2400Mhz GPU: Radeon Pro 555X 4GB Storage256GB SCREEN: 15"
11 minutes ago, Joseph87654 said:
budget is around 2700 USD
Would this be something you would go for?
http://deals.dell.com/productdetail/tts
Dell's gaming line is very good value but the lower end models screen is sub-par with a quick response panel, unless thats what you want.
Their top end model is quite an attractive model and has a great IPS screen: http://www.dell.com/au/p/inspiron-15-7577-laptop/pd?oc=sma511071au&model_id=inspiron-15-7577-laptop
KRONOS:
// AMD FX 8350 // ASUS ROG CROSSHAIR V FORMULA Z // G.Skill Ripjaws 16GB 2x8 1866Mhz DDR3 // ASUS ROG STRIX GTX 1070 OC // CORSAIR SPEC-03 // Kingston SSD v300Now 120GB, 1TB WD Blue // Cooler Master V750 750W // 1x BENQ GL2760H 1080p 60hz 2ms // Corsair H75 CPU Cooler // Razer BlackWidow Ultimate Battlefeild 4 Collectors Edition\K70 RGB Lux Cherry RED // Razer Deathadder Chroma // Logitech G213 Speakers // ASUS ROG MARS GTX 760 X2 (Retired) // Windows 8.1
1 minute ago, Joseph87654 said:
yeah i would go for this but im not sure if it could handle workstation apps?
I say it would, it has an i7 7700HQ, 4 cores, 8 threads. Plus a full size 1050. :) If you want, for a cheaper one, With a better GPU such as a 1060 and it has the same CPU plus an additional 1TB drive albeit it's 5400 (which isn't the fastest)
http://www.dell.com/en-us/shop/dell-laptops/inspiron-15-7000-gaming/spd/inspiron-15-7577-laptop/dncwfs615h
thank you so much, i really appreciate your help! I will most likely get the xps now!
Glad I could help. :D
Would you happen to know how much battery life the 56w config of this laptop has? Mainly when doing mundane internet browsing/youtube videos(not at 4k)
same with the 96w config.
I'd say for light use, a good 5+ hours maybe more.
Really with this budget you should probably get a MacBook Pro.
Mind as well get all the luxury you could want and all the power you need.
- 16gb of ram
check new surface pro..
MF UH BEANS
https://www.ebay.com/itm/ASUS-GL753VE-DS74-17-3-GTX1050Ti-4GB-i7-7700HQ-16GB-RAM-256GB-SSD-1TB-HDD/302594014374?epid=588610638&hash=item4674023ca6:g:eYAAAOSwFmxaUm55
MF UH BEANS
