Hi, so I just have a really random question haha,I just bought a new case and it has 2x 120mm fans in the front  and it has a power supply cover. So should I keep one of the fans on the bottom front so it blows over the power supply sense it's closed off, or do I not need a fan there and can just move it to the top of the case or something?
https://linustechtips.com/topic/885554-airflow-questions/
What are your specs?
https://linustechtips.com/topic/885554-airflow-questions/#findComment-10935396
What case? Seems odd that it would only have 2 intakes at front. If it has 3 fans, 2 in front and 1 at rear, leave them as is. Thats default airflow config and will be fine for 80% of builds.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/885554-airflow-questions/#findComment-10936543
