زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/885520-small-cpu-cooler/#findComment-10934030
OR take a look at EKL Alpenföhn Silvretta or Panorama.
I used the Panorama to cool an overclocked E4300, and overclocked E8400 without any problems.
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
https://linustechtips.com/topic/885520-small-cpu-cooler/#findComment-10934033
1 minute ago, Jageth-theth said:
that's to large. my case is about 4"
This then...
https://pcpartpicker.com/product/Lbhj4D/cryorig-cpu-cooler-c7
زندگی از چراغ
https://linustechtips.com/topic/885520-small-cpu-cooler/#findComment-10934037
The L9i (37mm/1.5in) is seen as one of the best SFF coolers; however, it's still not good for high wattage chips.
Information such as the specific case and the CPU would help tons
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
https://linustechtips.com/topic/885520-small-cpu-cooler/#findComment-10934040
1 minute ago, Imbellis said:
The L9i is seen as one of the best SFF coolers; however, it's still not good for high wattage chips.
3 minutes ago, xc3ll said:
A little more details please!
What CPU? Do you plan to overclock?
And what case/space are we talking about? If you don't know the case, a picture would be great.
I am using a i5-8600
no I will not overclock
this is the case
https://linustechtips.com/topic/885520-small-cpu-cooler/#findComment-10934048
I very highly recommend that you don't do that. It's much much better just to get an SFF case (List of 'em here) I recommend the SG13B or FD Nano S. Those cases are around the size of that briefcase and are much easier to work in. I'd recommend asking the forum which cases are best.
As for the briefcase design - they usually don't end up well. Much more work, time, and money spent on 'em rather than just going with an SFF case that's designed to do it.
(something I threw together a couple years ago - the concept was fun but not practical.)
https://linustechtips.com/topic/885520-small-cpu-cooler/#findComment-10934060
Still what would you suggest for a CPU cooler with a i5 8600
https://linustechtips.com/topic/885520-small-cpu-cooler/#findComment-10935333
What currency are you using?
How much clearance do you have for the cooler and how do you plan to layout the system cooling? System specs?
Is there going to be a cutout or vent above the cpu cooler?
https://linustechtips.com/topic/885520-small-cpu-cooler/#findComment-10935446
