Help! package java.time.chrono does not exist on eclips
By the sounds of your post it's too late, but for anyone else who comes across this, java.time.chrono is only available from Java 8 (at the bottom of the doc page, it says "Since: JDK 1.8"), so if it's being compiled using Java 7 instead you will get that error.
If you are in control of the build environment, you can fix this by making sure you have Java 8 or later installed (from Oracle or OpenJDK), but if you don't then you will need to remove the dependency on that package, and either use a third party dependency or implement the features yourself.
HTTP/2 203
