2 minutes ago, Audherbagn said:
I have a corsair strafe with mx browns, and I have been using the "rain" preset in cue since the day I got it over 2 years ago, and I just now noticed that one of my switches is missing its LED. is this possible to fix?
short answer no
long answer if you are able to find the switch for sale and able to get it off the Circuit board and re solder the new one on it may work/Not ,  if its just the led just deal with it or buy a new keyboard .
main rig
 corsair 750d | evga 1000w g2 | Gigabyte x99 soc champ | 5820k 4.0GHz | 1tb wd blue | 250gb samsung 840 evo  | Crucial Ballistix Sport XT 16GB 8x2 DDR4-2400 | MSI GTX 970 x2 | monitor Acer B286HK 28" 4K | razor chroma blackwidow  | razor death adder chroma
CENTOS 7 SERVER (PLEX&docker stuff)
NZXT s220 | evga 500w 80+ | AMD FX 8320e | ASUS M5A78L-M/USB3 | 2x8gb non ecc ddr3 WD red 2TBx2 | seagate 160gb microcenter 8gb flashdrive OS
Sure, just open it up (keep in mind this will void your warranty according to the manufacturer) and solder in an LED.
11 hours ago, gamerking said:
short answer no
OP would just have to install an LED (assuming the circuit board is set up correctly), he really doesn't have to install an entire new switch.
If OP has the equipment, this will only cost a dollar or so to install and will.only take an hour or so. This is not a reason to get a new keyboard for (IMO).
over 2 years hes got no warranty so hes SOL , its either try to fix it him self or buy a new one , unless corsair fixes it for free i dont see this happening
main rig
