Hey guys I'm not to great with hardware and all help would be appreciated.
I looking for some help.
I'm looking at buying a 1440p 144hz monitor and i have a 1920x1080 60hz already i want to run dual monitors.
My set up i have is
i7-6700k 4ghz not overclocked
16gb ram
geforce 970
Will i be able to run two screens with out it being to demanding on my computer?
Will i need to upgrade my screen situation or what should i do ?
https://linustechtips.com/topic/884653-1440p-144hz-help/
2 minutes ago, Newbie Tech said:
1440p 144hz
geforce 970
A 970 is barely enough for 1080p 144fps on most games with settings turned down (I have this config, I'd know) You wont get the full 1440p 144hz out of the panel unless you're running less demanding E-sports games.
However, running dual screens put no more strain on the GPU as one would.
https://linustechtips.com/topic/884653-1440p-144hz-help/#findComment-10926418
In some cases gpu or windows can have problems running at two different framerates.
My GTX 760 stuttered with 2x1080p 60Hz
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
https://linustechtips.com/topic/884653-1440p-144hz-help/#findComment-10926434
On a stronger GPU, it shouldn't be an issue. I've personally never heard of a 970+ having issues displaying just a couple of window images or simultaneous videos.
https://linustechtips.com/topic/884653-1440p-144hz-help/#findComment-10926442
Just now, Newbie Tech said:
I can run 2x1080p with no problem,
Would i be able to buy a 1060 or something cheaper and run SLI?
Also would i be able to run 1440p 144hz with only one monitor or would the problem still remain ?
sli is only for 1070's and above.
https://linustechtips.com/topic/884653-1440p-144hz-help/#findComment-10926462
so if i get a 1070 can i sli with a 970 or will that not work at all?
You can only SLI GPUs of the  same type.
So no: you cant SLI a gtx970 with a gtx1070
Desktop: Intel i9-10850K (R9 3900X died 😢 )| MSI Z490 Tomahawk | RTX 2080 (borrowed from work) - MSI GTX 1080 | 64GB 3600MHz CL16 memory | Corsair H100i (NF-F12 fans) | Samsung 970 EVO 512GB | Intel 665p 2TB | Samsung 830 256GB| 3TB HDD | Corsair 450D | Corsair RM550x | MG279Q
Laptop: Surface Pro 7 (i5, 16GB RAM, 256GB SSD)
Console: PlayStation 4 Pro
https://linustechtips.com/topic/884653-1440p-144hz-help/#findComment-10926472
Additional screens don't tax your GPU any harder (except while idle but that only affects idle power consumption). A higher resolution screen will give you lower framerates if you game on it though.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/884653-1440p-144hz-help/#findComment-10926475
Can anyone recommend a good 1080p 144hz monitor ?
I personally use the asus mg248q
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
https://linustechtips.com/topic/884653-1440p-144hz-help/#findComment-10926499
