Just now, CooperMyers said:
will this reoccur?
Restart your PC and find out :)
https://linustechtips.com/topic/884427-i-need-help/#findComment-10923841
The title of the box says instant flash, which might indicate a bios flash tool. Did you have a usb jump drive in your bios flash port on your motherboard? Were you trying to update your bios?
I personally would flash my bios to the most recent update to ensure that my bios is not corrupted. I know there is a minor risk of flashing your bios, but if done properly it will be just fine.
CPU: Ryzen 7 2700x cooled by Pure Rock Slim // RAM: Gskill Flare X 3200mhz CL14 2x16 32GB// GPU: Powercolor Red Devil RX 6650 XT 8GB// Motherboard: ASRock B450m Pro 4 // PSU: Seasonic G550 Gold 80+ // Storage: 4TB pcie nvme game drive, 512 GB m.2 sata3 OS Drive, 4 TB WD Red HDD // Monitor: Samsung S22D300 21.5" 1080p 60Hz, MSI 27" 1080p 144hz Freesync 1ms display // Peripherals:  Logitech fancy shmancy keyboard and moise with rgb and gaminess stuff, very fancy | Kingston HyperX Cloud Core headset
https://linustechtips.com/topic/884427-i-need-help/#findComment-10924874
Maybe you accidentally pressed the key on your keyboard, which starts the flash utility, during post?
My R2700XT build:  r7 2700 @4.1 Ghz max 65C - Sapphire Pulse rx 5700xt @1625Mhz 955mV 1300rpm fans, max 82C - Asrock B450 gaming k4 - Gskill Ripjaws 2x8GB @3200mhz CL16 - Be Quiet Straight Power E11 650w - Fractal Meshify C - EK-Kit S240 - NB eLoop 120mm PWM - Be Quiet Shadow Wings 140mm 1000rpm - Bitfenix Spectre LED PWM 120mm - Samsung 250GB 860 Evo - Seagate Barracuda 2TB
Peripherals:  Acer XF270HBbmiiprzx 144hz 1080p TN - CM Storm Quickfire TK - Coolermaster MK750 - CM Storm Reaper - Logitech G303 - Logitech G502 - Logitech G603
Audio:  Hyperx Cloud Stinger - Samson SR850 - Trust Screamer - Creative Gigaworks T20 II
https://linustechtips.com/topic/884427-i-need-help/#findComment-10927515
