Hi! In my computer i have an ASUS m5a99x evo r2.0 Motherboard, and an AMD FX-6350
The MOBO have been stuck on POST when starting a couple of times. Neither BIOS or boot loads... Reset does not help. But what helps is a total system power-loss.
I unplug the computer for 10 seconds, and reconnect it. Then is boots fine... This fault have happened two times in about two weeks.
Have anyone heard of this fault before? The motherboard is about two years old, and the CPU is about 5 years old :P
Sorry for sloppy english :/
https://linustechtips.com/topic/884298-wierd-mobo-issue/
I've seen this problem before myself with Old hardware. (between 6 and 10 year old mobo's, 24/7 usage) For me, the BIOS chips would degrade. If it's the same for you, you could try to update/downgrade/change your BIOS version and check if it makes a change. (the most important thing here is to rewrite data to your BIOS)
Another thing you might want to consider to bypass this problem, is putting the pc in sleep mode. That way, it isn't really turned off, and it will skip parts of the BIOS. It's not an cold start. (and also, your load times will most likely improve when starting up this pc) Power draw is minimal during sleep mode, and noise is non exsisting.
https://linustechtips.com/topic/884298-wierd-mobo-issue/#findComment-10922718
my mobo (z270) got stuck on post because I had a pendrive in the frontpanel usb.
The above answer sounds legit, too, try it.
My R2700XT build:  r7 2700 @4.1 Ghz max 65C - Sapphire Pulse rx 5700xt @1625Mhz 955mV 1300rpm fans, max 82C - Asrock B450 gaming k4 - Gskill Ripjaws 2x8GB @3200mhz CL16 - Be Quiet Straight Power E11 650w - Fractal Meshify C - EK-Kit S240 - NB eLoop 120mm PWM - Be Quiet Shadow Wings 140mm 1000rpm - Bitfenix Spectre LED PWM 120mm - Samsung 250GB 860 Evo - Seagate Barracuda 2TB
Peripherals:  Acer XF270HBbmiiprzx 144hz 1080p TN - CM Storm Quickfire TK - Coolermaster MK750 - CM Storm Reaper - Logitech G303 - Logitech G502 - Logitech G603
Audio:  Hyperx Cloud Stinger - Samson SR850 - Trust Screamer - Creative Gigaworks T20 II
https://linustechtips.com/topic/884298-wierd-mobo-issue/#findComment-10927636
