i have a old pc
config
. Core-i7-4770k
.gigabyte z87-hd3
16 gbs of ddr3 gskill 1600 bus memory
a ONLY 2 tb hdd
Thermaltech psu smart se-530 watts
A GTX 1070 strix
Now for some reason my motherboard killed itself so now ive to change it,,,,,and i am not going to buy a old mobo
so I decided to buy
A core i7-8700K
ASUS ROG STRIX Z370-F GAMING LGA1151 DDR4 4000MHz Mainboard with Aura Sync RGB, Dual M.2, SATA 6Gbps and USB 3.1 for 8th Generation Intel Core Processors
2 X G.Skill Trident Z F4-3200C16D-32GTZ 16GB DDR4 3200 BUS Desktop RAM- 32 gb total
Seagate ST4000DM005 4TB SATA 7200RPM 3.5" Barracuda35 HDD (Desktop)
And i want use my old pc's
A GTX 1070 strix
And my question is
What ssd or m2 or nvme should i buy
and will nvme or m2 will support with my 1070
as my processors pci lane in 16
And I am running short on budget
i don't want to buy a PSU???
will it work with the new set up
Please help mee.....
And the pc is for Video Editing and animation......i run 3 monitors (reason of 32gigs of ram)
https://linustechtips.com/topic/884130-upgrade-issues/
NO BUY A PSU!
It will work, but that PSU is just...
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/884130-upgrade-issues/#findComment-10920686
-moved to troubleshooting-
https://linustechtips.com/topic/884130-upgrade-issues/#findComment-10920697
2 minutes ago, Farhan E Husnain said:
you mean it will work....but just bad???
and which one should i buy.... and about storage??do  u have any suggestion
A cheap (actually, depends on your reason) CX450, or Pure Power 10 will do.
If you aren't 4k video editing, I can recommend the Crucial MX300 (best price to performance) and the Samsung 850 EVO (best speed for a low price, faster than MX300)
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/884130-upgrade-issues/#findComment-10920706
well i am editing 4k....
https://linustechtips.com/topic/884130-upgrade-issues/#findComment-10920708
Then go for something like the Samsung 960 EVO or PRO.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/884130-upgrade-issues/#findComment-10920727
I agree, I'd strongly try and find the money for a PSU. Judging from your budget, you should easily be able to spare $70ish for even a CX550M.
NVME will run off the chipset, not the CPU, so you're fine for lanes.
Wouldn't it be more....build planning?
You know. Not questioning your authority or decisions, my liege.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/884130-upgrade-issues/#findComment-10920729
well okay then, will this will be okay...its also 70ish
it costs 5400 in my country lol....~$67.5 US
Corsair VS650 650W Power Supply Unit (PSU)
https://linustechtips.com/topic/884130-upgrade-issues/#findComment-10920743
Yeah I suppose... guess I should have read it more carefully lol
https://linustechtips.com/topic/884130-upgrade-issues/#findComment-10920750
well also can u please name me 256 gig nvme, m2 ,bla bla
i have no idea about this
https://linustechtips.com/topic/884130-upgrade-issues/#findComment-10920753
No, the VS is crap. Just get one of the suggested ones.
https://linustechtips.com/topic/884130-upgrade-issues/#findComment-10920761
Mmmm....no, I wouldn't. Check out this list, and pick something from (preferably) tier 1, if not tier 2.
Haha, title blindness ;) I see what you did. I would have thought the same. Issues -> trouble -> troubleshooting.
It's too late for thinking.
960 EVO is pretty much king. Looking at your budget, I'd just go with that.
https://linustechtips.com/topic/884130-upgrade-issues/#findComment-10920762
ok i am gonna buy
Samsung EVO 960 NVMe M.2 250GB SSD
but still not sure about the psu
https://linustechtips.com/topic/884130-upgrade-issues/#findComment-10920793
well i have finalized
Intel Coffee Lake Core i7 8700K 3.70-4.70GHz, 6 Core, 12MB Cache LGA1151 8th Gen. Processor: 32,200~$402.5
ASUS ROG STRIX Z370-F GAMING LGA1151 DDR4 4000MHz Mainboard with Aura Sync RGB, Dual M.2, SATA 6Gbps and USB 3.1 for 8th Generation Intel Core Processors: 18,800~$235
G.Skill Trident Z F4-3200C16D-32GTZ 16GB DDR4 3200 BUS Desktop RAM: 14,600 X 2 = 29200~$365
Seagate ST4000DM005 4TB SATA 7200RPM 3.5" Barracuda35 HDD (Desktop) : 11,100~$138.75
Samsung EVO 960 NVMe M.2 250GB SSD : 11,800~$147.5
Thermaltake CLP0607 NIC C4 (120mm) Air CPU Cooler: 5,100~$63.75
Value Top VT-TR900S Gaming Silver Casing: 3,600~$45
Powerpac 850VA UPS : 3,100~$45
I Don’t know power supply : 8,000~100-----i dont know my name as well as PSU.....
Total : 122,900~$1536.25
https://linustechtips.com/topic/884130-upgrade-issues/#findComment-10920887
